AutoCAD Forum
Can't select faces for izmo
4 REPLIES 4
Karol-Or
354 Views, 4 Replies
I use 2013. in the solid attached i place the crosshairs on any face, press Ctrl to scroll through selection but the faces i want don't appear in the list
4 REPLIES 4
imadHabash
in reply to: Karol-Or
from properties dialog change History to None (see below image). then you will notice that Ctrl click will work well.
Imad Habash
Karol-Or
in reply to: imadHabash
but the gizmo axes aren't perpendicular to the faces.
I set the UCS at one corner with axes perpendicular and tried to move a face who's axes weren't perpendicular. the face moves perpendicularly all right but the amount isn't exact since still it's movement follows it's not perpendicular axes
imadHabash
HI,
>> but the gizmo axes aren't perpendicular to the faces. <<
Yes..this is the problem you have always to be parallel with the ucs to easily manage your model. for that i use 3DALIGN for your model and align it as well. (see attached CAD file ). OR for such a purpose i suggest to use PRESSPULL command.
Good Luck..
Imad Habash
Karol-Or
See the picture, the UCS is parallel but the gizmo axes not
Forma Design Contest
AutoCAD Beta
