I output some sheets by Revit to DWG.
And then trying to print them all (to PDF) by sheet set in CAD.
But failed.
I guess is cause by this problem.
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-0CA2EE37-8E8E-486F-8527-187A5C1F403D
Why I need to open (and edit) every Layout before print?
Since I've opened every, why don't I just print them myself.
Solved by pendean. Go to Solution.
It must be how Revit creates DWGs versus AutoCAD. How many sheets do you have? Do you have access to the Autodesk Batch Save Utility.
