can't modify the line width
Hello! I ccan not made the wall's line behind the bed thinner, the wall is a mesh, it  was exported as a 3d from 3dsMax. Also I can make the line thicker but not thinner, this applies to all the imported objects(see the night stand). Is there a way to solve it? Or can I convert this mesh into a block(like the bed)?bridje.jpg
imadHabash
did you mean that while plotting or what ?  also wee need a CAD dwg file please for testing .
Imad Habash
I sent the file, i try to modify the line on the model sheet. I forgot to say that I am a beginner so sorry if I do not understand many things
imadHabash
you may need to turn OFF  LWDISPLAY ( System Variable ) .
Command: LWDISPLAY
Enter new value for LWDISPLAY <ON>: off
also you may need to :
  • change your visual style to 2D wireframe .
  • your file is too big ... try to clean it . >> Click <<
Imad Habash
it is not working, i can not modify the line, i can't even make it thicker, and before i could. what am i doing wrong?
