Can't import DGN file
mattias_piskanin
mattias_piskanin
Community Visitor
Community Visitor
Hi, i have issue with DGN file import.
When I try import the file it does do nothing. Some tips?
  • dgn
ianjchap
Hi @mattias_piskanin,
Some guidance om this here:-
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Import-of-a-DGN-fi...
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
paullimapa
where are these dgn files coming from?
can you share sample dgn for community to try?
Paul Li
IT Specialist
@The Office
ChicagoLooper
Are you running Civil3D?
Civil infrastructure? Surveying? Geotechnical?
You'll get better action in the Civil3D Fourm.
Chicagolooper
