Always load a auto lisp
gotphish001
Advisor Advisor
Message 1 of 8
gotphish001
When you appload a lisp it asks you if you always want to load it or just once. I usually only load always if it's something I constantly use that and I like to make sure a lisp works without problems before I do that too. I have a lisp that I was only loading once, but now I want to load it always. I don't get the dialog box that asks any more however. How to I get it to load always or get the dialog that asks back to pick that option?
I know there is a way to make autocad re-ask you all the questions that you checked the box for don't ask this again. I can not for the life of me find where that is or find my bookmark that talks about that. I know I have done it before when I was fixing my geo maps issue.
Nick DiPietro
Cad Manager/Monkey
Replies (7)
Message 2 of 8
imadHabash
HI,
if i understand you right ..... APPLOAD command >> startup Suite .
Imad Habash
Message 3 of 8
ВeekeeCZ
Check Options/System tab
There are General Options with Hidden Messages Settings
and also Security setting. Lower the level if you mind that loading dialog.
Message 4 of 8
gotphish001
I thought those were it, but I can't get them to make a difference. On some lisps I get the dialog box in the image below. However I do not get this dialog for the lisp that I want to always load now.
Nick DiPietro
Cad Manager/Monkey
Message 5 of 8
ВeekeeCZ
How about add the file path between trusted locations?
Message 6 of 8
Kent1Cooper
@gotphish001 wrote:
.... On some lisps I get the dialog box in the image below. However I do not get this dialog for the lisp that I want to always load now.
That's not asking whether you want it always loaded whenever AutoCAD is started or a drawing is opened.  It's asking whether you always want to accept  loading of it when you explicitly go after it with something like APPLOAD, without being asked for a confirmation, despite its being from a non-verified source in a non-trusted location.  But you still need to ask for it to be loaded every time -- it just won't ask for the OK to load it once you've picked that option for it.
The one you "want to always load now" is probably either in a trusted location, or you've previously picked the Always Load option for it, either of which would explain why it doesn't ask that any more.
If you want something loaded every time you start AutoCAD or open a drawing, you can have an acaddoc.lsp file always load it, with a (load) or (autoload) function, or as already mentioned you can put it in the Startup Suite.  Or if it's in plain AutoLisp code [i.e. not some compiled format that you can't get into], you can include that code directly within acaddoc.lsp itself.
Kent Cooper, AIA
Message 7 of 8
gotphish001
I guess it helps if you actually read the dialog boxes. haha It's been popping up for so long on some lisp that I apparently just thought it said something else.
Nick DiPietro
Cad Manager/Monkey
Message 8 of 8
random_hard
Community Visitor
Community Visitor
Sorry for being late, If I'm not mistaken.
