AutoCAD Forum
Can't get rid of unwanted linetypes.
23 REPLIES 23
Message 1 of 24
StumpMasterFlex
9509 Views, 23 Replies
I am building a template.  In that template I brought over some legend info etc.  somehow my template went from 10 linetypes to 500.  I tried deleting some of the lines but AutoCAd says
The selected lintype was not deleted.  The following lintypes cannot be deleted.  Linetypes By Layer, ByBlock and Continuous, The Current Layer linetype, X-ref-dependent linetypes, Linetypes reference by layers or objects.
 I purged the drawing and also purged the nested objects.   They will not be deleted.  In the purge frame I click the bottom items that cannot be purged and there are a tonne of blocks that I assume these linetypes are associated too.  But can't delete them.
Any ideas on how to get rid of these blocks or linetypes?
Kindest Regards
Michael,
Civil Design Technologist (Exploration Technologist)
Civil 3D 2013
Windows 8
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
32. GB
64-bit Oepration System, x64-based processor
No Pen or Touch Input
23 REPLIES 23
Message 2 of 24
Patchy
in reply to: StumpMasterFlex
Message 3 of 24
StumpMasterFlex
in reply to: Patchy
Thx, we will investigate and let you how it works out.
Kindest Regards
Michael,
Civil 3D 2013
Windows 8
32. GB
Message 4 of 24
pendean
Start EXCHANGE inside AutoCAD, go to the Apps Store, download a freeware plug-in called DWG-PURGE: it does what the hotfix does without all the clunky procedures.
Message 5 of 24
artc2
in reply to: pendean
I don't know about the appstore app, but the hotfix is two parts.  One is a .NET app that will purge out existing unused dgn linetypes.  The other part is an update/fix to a module that's part of AutoCAD and controls how wblock (which is used by copy to clipboard) deals with dgn linetypes.  The second part is needed to prevent this problem from happening again in the future.
Message 6 of 24
Thx.  We will investigate.
Kindest Regards
Michael,
Civil 3D 2013
Windows 8
32. GB
Message 7 of 24
jggerth
You are running Civil3d -- is it possible that those linetypes/blocks are referenced by your civil3d styles?  Try exporting your template to a vanilla Acad file, (ExportToAutoCAD), then open in your plain AutoCAD (Civil3D As AutoCAD icon), and see if they can be purged that way.
Message 8 of 24
Thank you that worked like a charm.  Very easy to install and run.  Exactly what I was looking for.
Kindest Regards
Michael,
Civil 3D 2013
Windows 8
32. GB
Message 9 of 24
StumpMasterFlex
in reply to: Patchy
Thanks for you help, I never got to try your solution and accepted the solution for the free DWG-Purge download from the App store.
Thanks anyways for taking the time to help.  It was much appreciated.
Kindest Regards
Michael,
Civil 3D 2013
Windows 8
32. GB
Message 10 of 24
StumpMasterFlex
in reply to: artc2
Kindest Regards
Michael,
Civil 3D 2013
Windows 8
32. GB
Message 11 of 24
Message 12 of 24
For remove unused / unwanted line type.... Step-1 Save as your drawing to .dxf format & step-2 => open .dxf file and now purge in .dxf file...=> step-3 after purge.. use "audit" command and audit your drawing ... again used purge command .... => => save your .dxf file to .dwg. file ... enjoy... all unwanted/unused line types are deleted... From.. Bhavesh... Email: bhaveshparekh4@yahoo.com & gmail.com
Message 13 of 24
thank you my problem solve now!Smiley Happy
Message 14 of 24
jebubu00
I cannot seem to find DWG-PURGE in the App Store
Message 15 of 24
jebubu00
I cannot find DWG-PURGE in the App Store.
Tags (1)
Message 16 of 24
nestly2
in reply to: jebubu00
If using AutoCAD2015, it's built into the Purge command, otherwise you can get the hotfix here
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hot...
Message 17 of 24
jebubu00
That worked great. Thanks!
John Bailey
DC Engineering | 1475 Heritage Pkwy #305 | Mansfield TX 76063
Phone 817-225-2787 | Cell 469-955-4494 | JBailey@DCEngineering.net
[cid:image001.jpg@01CDAABF.0E73FBD0] [cid:image002.jpg@01CDAABF.0E73FBD0]
www.DCEngineering.net
P Save a tree. Please do not print this email unless necessary.
Message 18 of 24
acruz
Thanks for your tip and the DWG-Purge app! It removed all the pesky linetypes that the ordinary Purge command can't get rid off.
Message 19 of 24
This does not work for 2013 LT version.
Any help for poor LT users?
Message 20 of 24
Johneng
See below link.  Ignore the top half of the link as the solution posted can not be used with LT. Skip down to the section titled AutoCAD LT and the DGN Hotfix and follow the advice below there.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Forma Design Contest
AutoCAD Beta
