Can't erase objects
Can't erase objects
mdieckmeyer
Message 1 of 14
Can't erase objects
mdieckmeyer
I got this base drawing and started working on it and when I zoomed out I saw these objects and I can't select them and erase them.
Any clues?
See attached.
Accepted solutions (3)
Replies (13)
Message 2 of 14
imadHabash
i suggest first to disable hardware acceleration from 3DCONFIG command. if NOT fixed please attache your drawing here to help you more.
Imad Habash
Message 3 of 14
GÖÖÖ
did you tried (ampowererase) and after that the command (all) ?
it is possible do upload the drawing?
best regards
Message 4 of 14
imadHabash
>> did you tried (ampowererase) and after that the command (all) ? <<
(ampowererase) .... is this CAD command ? would you please guide us or show us an image on how to deal with?
Imad Habash
Message 5 of 14
ennujozlagam
@mdieckmeyerhello, can you post your file so we can check. thanks
Message 6 of 14
GÖÖÖ
hi,
thats just a command to delete, watch my screencast. my Intention was just to see if he can delete everything with this command. if not there is an other issue.
here a Link to see more Information about the command.
https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/201...
best regards
Message 7 of 14
imadHabash
oh yes ... now it's clear. since we have plain AutoCAD and this command didn't exist in our versions as your AutoCAD Mechanical.
Many thanks.. 🙂
Imad Habash
Message 8 of 14
mdieckmeyer
Thank you  for the response, I will try this in the morning when I get to my office.
I attached the file
Message 9 of 14
mdieckmeyer
I have Auto Cad 2017
Message 10 of 14
GÖÖÖ
try this out and have a nice day. it was some really strange stuff 🙂
Message 11 of 14
imadHabash
since we have your CAD file it wasn't hardware acceleration issue and as seen in below image i notice two big unselectable circles !!! i don't know from where they come maybe it's a scale matter for some items. to get rid of them just switch to any layout (T1 cover) and get back to model to found that you can select them and delete.(see attached CAD file)
Good Luck...
Imad Habash
Message 12 of 14
GÖÖÖ
i solved his problem, just watch my screencast.
Message 13 of 14
mdieckmeyer
Thank you for your help, that did it!
Message 14 of 14
I have an unwanted an Autodesk Fusion 360 file that will not erase and it is taking up unwanted disk space.
