AutoCAD Forum
can't edit dimensions, text, or explode them
11 REPLIES 11
Message 1 of 12
6114 Views, 11 Replies
can't edit dimensions, text, or explode them, i'd finding stuff that i can't edit across drawings, anyone had this problem before and how to solve ?
11 REPLIES 11
Message 2 of 12
rendermaster
exploding text can be done with express tools
see more discussion here:
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/text-explode/td-p/5624581
dimensions can be explode, however in your case, would you mind to share that cad file for us to see the problem ( just isolate that particular object copy and paste it to a new file if it is a big file)
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 12
in reply to: rendermaster
i uploaded here, thanks in advanced for looking at it
https://we.tl/h2f3RdJy40
Message 4 of 12
iv not check how much i can't edit but so far its the dimensions and text
Message 5 of 12
rendermaster
your file is doing fine on my side, text and dimension can be exploded
Message 6 of 12
oh gosh must be on my end then, have no idea how to fix this
Message 7 of 12
Alfred.NESWADBA
Looking to your uploaded drawing I can edit attributes in the titleblock by double click the title block, I can edit text in the layout with a double click, I can edit dimension text (in modelspace and paperspace, you used both types).
So you can first verify, that
PICKFIRST is set to 1
DBLCLKEDIT is set to ON
If that does not help then please specifiy the object in your drawing that you can not edit and tell us what (exactly) you do to get that object in edit mode.
It's also good to know if that happens only in this drawing or also in other drawings.
Please let us know which AutoCAD version and service pack you are using.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 8 of 12
in reply to: Alfred.NESWADBA
where do i find pickfirst=1 ?
Message 9 of 12
Alfred.NESWADBA
HI,
The fastest way with systemvariables is: type PICKFIRST<ENTER> into the command line and then enter the new value, followed by <ENTER>.
Within the _OPTIONS dialog you can find it there:
- alfred -
Alfred NESWADBA
Message 10 of 12
solved it now
i did a system restore back to about 2 weeks ago, has done the trick, my IT support for work were no help either, what are we paying them for ?
thanks for every ones help much appreciated what a great community
Message 11 of 12
jggerth
Expecting IT support to have an in-depth understanding of all the nuances of AutoCAD and verticals is unrealistic.  After 3 decades of running CAD applications I'm still learning things, so having the notion that a network/pc support person would know Acad is more preposterous than thinking politicians have your interests at heart.
Message 12 of 12
in reply to: jggerth
right and they couldn't have suggested that i do a restore which has 0 to do with Autocad, perhaps you should a little more thinking before you post a reply next time
AutoCAD Inside the Factory
