My units are set to Architectural and the angle type is set to the right precision.
Yet, I can't draw a line using DMS.
For example, I insert the first point on the screen (arbitrary point), press "@", then give the length, press "<" and insert my angle 76d55'13''.
When I press Enter, I only see the box is highlighted in red.
Couldn't find the solution on the forum or anywhere else.
My only guess is maybe I need to change a system variable...
Any suggestions?
Thank you,
Oran
I don't yet know what causes the problem ( bug?, and it only occurs if "clockwise" is activated), but if you turn off the dynamic input it works well.
FYI: In ACAD 2021 it work well as expected.
Jürgen Palme
In the meantime I saw this behavior in both versions randomly happen. Sometime it works well (in both versions). A moment later it fails, in in the same drawing. I have no idea how to avoid (or to provoke) this. Can't help, sorry.
Jürgen Palme
If you want to use bearings and distances, here's one I made up for use at home where I don't have Civil3D working.
(defun c:LineByDirection ( / *error* vars vals done p1 p2 quad bearing ang d)
;; John F. Uhden, Sea Girt, NJ, USA
;; Program draws lines by bearing and distance (like Land Desktop and C3D)
;; v1.0 (4-20-2020)
;; Bearing format is DD.MMSS but you can skip entering the SS if it is zero.
;; Quadrants are 1=NE, 2=SE, 3=SW, and 4=NW.
(gc)
(vl-load-com)
(princ "\nLineByDirection (c)2020, John F. Uhden")
(defun *error* (error)
(mapcar 'setvar vars vals)
(vla-endundomark *doc*)
(cond
((not error))
((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
(1 (princ (strcat "\nERROR: " error)))
(princ)
(setq vars '(cmdecho))
(setq vals (mapcar 'getvar vars))
(or *acad* (setq *acad* (vlax-get-acad-object)))
(or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
(vla-startundomark *doc*)
(mapcar 'setvar vars '(0))
(command "_.expert" (getvar "expert")) ;; dummy command
(defun @bearing2angle (quad bearing / dpos dd mm ss ang)
(if (setq dpos (vl-string-search "." bearing))
(progn
(setq dd (read (substr bearing 1 dpos)))
(or (setq mm (read (substr bearing (+ dpos 2) 2)))(setq mm 0))
(or (setq ss (read (substr bearing (+ dpos 4))))(setq ss 0))
(setq dd (read bearing) mm 0 ss 0)
(setq ang (+ (* (/ dd 180.0) pi) (* (/ mm 180.0 60) pi) (* (/ ss 180.0 60 60) pi)))
(cond
((= quad "1")(setq ang (- (* 0.5 pi) ang)))
((= quad "2")(setq ang (+ (* 1.5 pi) ang)))
((= quad "3")(setq ang (- (* 1.5 pi) ang)))
((= quad "4")(setq ang (+ (* 0.5 pi) ang)))
ang
;; Begin the action:
(if (setq p1 (getpoint "\nStarting point: "))
(while (not done)
(initget "1 2 3 4")
(or
(and
(setq quad (getkword "\nQuadrant (1,2,3,4): "))
(setq bearing (getstring "\nBearing (DD.MMSS): "))
(setq ang (@bearing2angle quad bearing))
(setq d (getreal "\nDistance: "))
(setq p2 (polar p1 ang d))
(vl-cmdf "_.line" "_non" p1 "_non" p2 "")
(setq p1 p2)
(setq done 1)
(*error* nil)
(defun c:LBD ()(c:LineByDirection))
John F. Uhden
