Can't delete lines
Can't delete lines
Message 1 of 11
Can't delete lines
I'm a complete beginner to AutoCad, so please forgive me!
I'd like to clean up a floor plan, so I can dimension it ready for construction. The plan has a lot of other lines for driveway, fencing etc all of which are not required. I've spent hours googling, and attempting different ways, but I cannot select these lines!
Replies (10)
Message 2 of 11
rendermaster
checked your layers and be sure that layer you want to delete is not locked
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 11
If you can see them but not select them, you might want to check if they are on locked layers, or are coming from a reference file.
To select the lines what method are you using? Pick, crossing window, non-crossing window etc.
Hope this helps
Message 4 of 11
All layers are unlocked, and all layers are unfrozen.
Message 5 of 11
Argh, they could be coming from a reference file, which I don't have. How can I check if this is the case?
I've tried all methods - pick, crossing window and non crossing window.
Message 6 of 11
carl.coghill
Are you able to upload the file so that we can have a look?
Carl Coghill
Senior Designer
AutoCAD 2018
Windows 7 Professional 64bit
LinkedIn
Message 7 of 11
Appreciate the fast responses, thanks guys!
Message 8 of 11
Vinayv4v
Seeing your white window, make sure you are not in layout tab.
Please upload a sample of your drawing.
Thanks & Best Regards
Cheers,
Vinay Vijayakumaran
Message 9 of 11
Anthony_Latoche
 SALUDOS: @Anonymous
BUENOS DÍAS ACABO DE VER TU DUDA Y ESPERO TE SIRVA LA SOLUCIÓN:
TE RECOMIENDO QUE EL DIBUJO LO EXPLOTES COMANDO EXPLODE Y POSTERIORMENTE LE DES EN SELECCIONAR SIMILAR, POR OTRO LADO TRATAR DE UBICAR LAS CAPAS Y BORRAR DE MANERA CONTINUA.
SI LOGRÉ RESOLVER TU DUDA PUES PUEDES APOYARME CON 1 KUDO Y PONGAS ESTA AYUDA COMO SOLUCIÓN.
QUE TENGAS BUEN DÍA SALUDOS
TOPOCivilPeru SAC.
TOPOCIVIL PERÚ - Capacitaciones y Servicios para Ingeniería
Anthony Bagner Latoche Rosario - Gerente
https://www.linkedin.com/in/topocivilper%C3%BA/ / https://www.youtube.com/channel/UCJGPl0XrNzVSjcAdn4bzaDg / https://www.facebook.com/TopocivilPeru / https://topocivilperu.com/
Message 10 of 11
RvW000
Suggest that you check  that you do not have any block in your drawing which may have a construction line embedded in it. Especially if you have a 'smart' block which has visibility states. Double click the block and cycle throught he visibility states. You may find the culprit hiding in the block.
Message 11 of 11
slee005
Community Visitor
Community Visitor
thanks
