AutoCAD Forum
Can't Copy Text Field?
13 REPLIES 13
Message 1 of 14
965 Views, 13 Replies
The drawing has a "Out of Service" text field I can't select to copy and paste it. Is there something done that is protecting this text field?
13 REPLIES 13
Message 2 of 14
jrreid
All layers are Turned On, Thawed.. and Un-Locked?
Try this, Erase ALL.  See if that take care of it. Do this in MS and PS.
Hope this helps.
JRR.
Message 3 of 14
pendean
Show us: share the DWG file here.
Message 4 of 14
Looks like all layers are turned on except one layer name _KTI_Control shows a freeze snowflake vs. a sun?  Where do I check for Thawed and un-locked?
Message 5 of 14
Everything in the layers appears to be unfrozen and unlocked.
Message 6 of 14
I am using Autodesk DWG TrueView2019
Message 7 of 14
Here is the file.
Message 8 of 14
jrreid
Houston there's a problem... you asking where and how to thaw... turn on... unlock layers....
Anyway. Did you try Erase All in PS and MS?  (Erase... enter....  ALL... enter..)
and... as Mr. Pendean requested, attach your drawing.. you will find the answer very fast.
Message 9 of 14
jrreid
The name erased right away.... I don't understand....
Message 10 of 14
user181
You can't copy objects or edit drawings with trueview. All you can do is view, print and get measurements with trueview. You need autocad to copy objects and edit dwg files.
Message 11 of 14
jrreid
Here is a trick to do.. it lets a text tag somewhere in your drawing.. but....
Do a FIND/REPLACE......  OUT OF SERVICE    then replace it with nothing... or a space.
Message 12 of 14
Thanks.  I opened it in AutoCAD Lt instead of letting the file open in Trueview.
Message 13 of 14
pendean
>>>... I opened it in AutoCAD Lt instead of letting the file open in Trueview...<<<
@Anonymous That's all it took, all is good now?
Message 14 of 14
in reply to: pendean
Yes
AutoCAD Inside the Factory
