Can i do the equal to operator command the same in Excel?
aldrinjade_faller
Observer Observer
aldrinjade_faller
Observer
Observer
I want to automate data in cad to excel. However, the data link command is only good for a single excel file making it difficult since i have a multiple tables and its more complicated. Im thinking the "equal" command (the same in excel) to make a seperate table where i can easily copy all the datas in a single table, rather that going through all seperated tables.
kaustubh_jagtap200
Community Visitor
Community Visitor
Yes, in Excel, you can use the equal-to (=) operator to create formulas and compare values, similar to how it's used in programming. Here are two main ways you can use it:
  1. Creating a formula:
    • To perform calculations, start by typing = in a cell, followed by the formula. For example, to add two numbers:
      Copy code
      =A1 + B1
  2. Comparing values:
    • To check if two values are equal, use the = operator. For example, to check if the value in cell A1 is equal to the value in B1:
      Copy code
      =A1 = B1
    This will return TRUE if they are equal, or FALSE if they are not.
Both uses are valid in Excel and can simplify calculations and logical comparisons.
aldrinjade_faller
Observer
Observer
Hello thank you for the response, I really appreciate it. The problem is im not sure if i can do it in AutoCAD, Is there any way?
