AutoCAD Forum
can I backup and restore my layer color assigments?
3 REPLIES 3
pwk
299 Views, 3 Replies
I am using AutoCAD 2016.  I have a drawing that has many blocks.  Each block includes objects drawn on several different layers.  The color for all objects is set to ByLayer, and I have different colors assigned to different layers.  There are times that I would like to change all objects in my drawing (even if they are inside a block) to a single color.  I can do this by using the -layer commands "Color" option, choosing a color, and using a wildcard "*" to assign this color to all layers.  The only problem is, I would like to be able to return to my original color scheme when I want to.  Can anyone tell me if there is a way I can "backup" all my layer/color assignments before changing everything to a single color so that I can "restore" my layer/color assignments at a later time?
Any advice will be greatly appreciated.
Thanks in advance,
Paul
3 REPLIES 3
in reply to: pwk
Look in Help for "Layer States". That will accomplish what you're looking for.
jggerth
in reply to: pwk
Two options come to mind.  If yoou're going to revert to a previous layer state in the same sessio, the LAYERP command will work.
Also explore Layer States in Help for a more robust, long term approach.
pwk
Thank you Michael!
That allows me to do exactly what I want!!
Forma Design Contest
