Can floating licenses be used over the internet or local LAN only?
stallonemike
Observer Observer
stallonemike
Observer
Observer
Sorry if this is a noob question, but my company said its OK for me to work remotely. They have a set number of floating licenses that users on the local LAN use internally. Is it possible to access one of them over the internet? if so, how is that to be set up?
Thank you
RobRocks
Talk to your IT and/or whoever handles the Autodesk licensing. Your organization should have directions for you.
stallonemike
Observer
Observer
That is why I am asking here...they are not very tech saavy and I just want to see if its even possible before they have to sub out an IT person.
Michiel.Valcke
I thought floating licences for AutoCAD had been discontinued a few years ago.
If you are still using that system, you can opt to 'borrow' a licence, this will 'permanently' reserve a license for your workstation, meaning you will not need to connect to the LAN network for a certain amount of time. You cannot however borrow a license indefinitely (max 3 months I believe) and while you have borrowed a license the LAN pool of licenses will have one license less to distribute to your colleagues.
https://www.autodesk.com/support/download-install/admins/network-deploy/borrow-a-license
If borrowing licenses is not a suitable solution for you, you will need to have access to the LAN server where the LMTools are installed, in practice this would mean that you have access to your office network through a VPN connection.
paullimapa
An alternative option would be to leave your work station in the office on and then from home remote into that work station and then start AutoCAD. Advantages to this method are:
1) no need to install AutoCAD on your home station
2) you have complete access to all licensed programs including AutoCAD
3) you have complete access to all files on the server
Disadvantage: you’ll most likely have to talk to your IT staff to make this happen
you may want to read an article I wrote awhile back covering this topic
Paul Li
IT Specialist
@The Office
stallonemike
Observer
Observer
Thank you all, these are very helpful and all great ideas. I think the CRD is the best option, all factors considering. Will give it go. Thank you.
paullimapa
You are welcome… cheers!!!
Paul Li
IT Specialist
@The Office
