AutoCAD Forum
Drawing recovery stuck
6 REPLIES 6
2740 Views, 6 Replies
Hi-
Looking for some ideas, I have a large xref and all of a sudden it won't open. I recieve the error that it is corrupted and need to run recovery & audit on it. No matter what version of CADD I try it gets stuck in the audit Pass 2. Of course project is due Monday. Anyone have any ideas how to recover?
Amy
6 REPLIES 6
pendean
Try the attached: did not use AutoCAD for fix it.
pendean
R2016 after a PURGE...
in reply to: pendean
That file works thank you so much! How did you get it to open before I posted I tried opening in 2016 but it would just hang up and not open?
john3Dpiping
It's great that you fixed their drawing but you didn't explain HOW you fixed it. I have the same issue. Every time I run recover, the drawing(s) hang up
I have same problem when I run the audit command. Drawing hangs on second pass and I have to CTRL/ALT/DELETE to hard stop ACAD
Please upload your dwg-file + let us know which version of AutoCAD you are using (and in case you have applications on top of AutoCAD running), so we can try to get it solved.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
autocad17Q2DD
Same problem here. Can someone help me?
AutoCAD Inside the Factory
