AutoCAD Forum
Can block receive parameter input?
4 REPLIES 4
540 Views, 4 Replies
Hi, here what i'm trying to achieve :
When you add a block can you make it request you to select a polyline object so you can use this polyline property into the block. Like create a quick tag to give the lenght of the selected polyline.
If its possible how to request it and how to acces it.
Tags (1)
4 REPLIES 4
pendean
Dynamic Blocks do not "request you" to do anything: if you want a user to get a prompt you will need to customize with LISP first.
in reply to: pendean
I'm not much familiarise with LISP but i do know code
Can you add a LISP script to a block?Or LISP are more like in the project template?
edwin.prakoso
You can't add LISP into a block.
LISP is a program to automate your task. For example in your case, you can run a LISP routine to place a particular block then it asks to select an object. The routine will read the object properties and input them in the block attributes.
Cheers,
Edwin Prakoso
in reply to: edwin.prakoso
Thanks I'll give it a look
AutoCAD Inside the Factory
