Can an ARX plugin be loaded through an SCR script file?
zhengyunyang2019
Message 1 of 10
zhengyunyang2019
I created an SCR file and input the command ("appload" "D:\work\ElecCoordinationSys.arx"), but it returned the error: "Error: Function error: 'appload' Command: APPLOAD."
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Did you test your code by typing that at the commandline first?
Does it work or give you the same error, or something else?
Message 3 of 10
Valentin_CAD
@zhengyunyang2019 ,
Check if the missing file is in the right folder for To Locate Support Files.
Or something like this:
/ld D:\work\ElecCoordinationSys.arx.
These links provide more help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 10
paullimapa
@zhengyunyang2019 Have you tried this updated version:
(arxload "D:\\work\\ElecCoordinationSys.arx")
Paul Li
IT Specialist
@The Office
Message 5 of 10
zhengyunyang2019
its the same error when i input it in cad commad
Message 6 of 10
paullimapa
Message 7 of 10
zhengyunyang2019
(ARXLOAD "D:\\work\\ElecCoordinationSys.arx")
You did it the right way. Thank you
And use "\\" in the path to take effect, not "\"
Message 8 of 10
paullimapa
Yes, either double backslashes "\\" or single forward slash "/" like this:
(arxload "D:/work/ElecCoordinationSys.arx")
Now if you add D:\work to your AutoCAD Options>Files>Support File Search Path then you don't even need to include the path in your loading code:
(arxload "ElecCoordinationSys.arx")
Paul Li
IT Specialist
@The Office
Message 9 of 10
zhengyunyang2019
Hello, I have a new problem, what if I want to load a dll file? Which command should I use?
I tried (netload "xxx.dll"), but the message "no function definition: NETLOAD"
Message 10 of 10
paullimapa
Did you try:
(command "netload" "xxx.dll")
FYI: You'll need to include the path if it's not located in one of the Support File Search Path
Paul Li
IT Specialist
@The Office
