Can an ARX plugin be loaded through an SCR script file?
zhengyunyang2019
zhengyunyang2019
I created an SCR file and input the command ("appload" "D:\work\ElecCoordinationSys.arx"), but it returned the error: "Error: Function error: 'appload' Command: APPLOAD."
Replies (9)
pendean
Community Legend
Community Legend
Did you test your code by typing that at the commandline first?
Does it work or give you the same error, or something else?
Valentin_CAD
@zhengyunyang2019 ,
Check if the missing file is in the right folder for To Locate Support Files.
Or something like this:
/ld D:\work\ElecCoordinationSys.arx.
These links provide more help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
paullimapa
@zhengyunyang2019 Have you tried this updated version:
(arxload "D:\\work\\ElecCoordinationSys.arx")
Paul Li
IT Specialist
@The Office
zhengyunyang2019
its the same error when i input it in cad commad
paullimapa
zhengyunyang2019
(ARXLOAD "D:\\work\\ElecCoordinationSys.arx")
You did it the right way. Thank you
And use "\\" in the path to take effect, not "\"
paullimapa
Yes, either double backslashes "\\" or single forward slash "/" like this:
(arxload "D:/work/ElecCoordinationSys.arx")
Now if you add D:\work to your AutoCAD Options>Files>Support File Search Path then you don't even need to include the path in your loading code:
(arxload "ElecCoordinationSys.arx")
Paul Li
IT Specialist
@The Office
zhengyunyang2019
Hello, I have a new problem, what if I want to load a dll file? Which command should I use?
I tried (netload "xxx.dll"), but the message "no function definition: NETLOAD"
paullimapa
Did you try:
(command "netload" "xxx.dll")
FYI: You'll need to include the path if it's not located in one of the Support File Search Path
Paul Li
IT Specialist
@The Office
