hey guys I got 2 images to help you understand my problem .
Is it possible to set a walll dominat that will automaticly cutoff a part of my camera view block, that if i turn the camera view path a bit , it will automaticly be adjusted. Sorry for my english.
would it help if you use _GROUP to group the camera + the wall to one (virtual) element. As long as PICKSTYLE is active whenever you select the camera and move or rotate it your wall will follow these modifications?
- alfred -
Hey Alfred,
Thank you for your reply,
But it doesn't solve my problem
Xanh
Why?
Without more information's from your side I don't know what is missing in my suggestion!
- alfred -
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I apologize but I am not really understanding your question. Is it possible to attach a file with the initial condition and then a copy of what you want it to do when you move the camera?
Perhaps a Screencast video will better explain what you are looking to achieve.
Hey Alred and John,
Thank you for your time.
I tried the following at Alfreds method, perhaps I did something wrong.
first I grouped the camera and the wall with the _group method, they became 1 group.
Next I used the command Pickstyle , and I selected the camera , than I tried to rotate the camera but I deselected the group apperantly.
what I try to do is: when I rotate the camera view against the wall , I want the wall to eat out the camera view(make that part dissapear or invisible).
If Im still not clear enough I will make a picture of what I want.
Kind regards,
Xanh
>> they became 1 group. Next I used the command Pickstyle , and I
PICKSTYLE is not a command, it's a system variable with different settings (>>>details<<<).
It should be set to 1 or 3 ... then a selection of any item of the group makes the complete group selected.
- alfred -
