AutoCAD Forum
Calculating Cubic Square Feet
7 REPLIES 7
Message 1 of 8
2567 Views, 7 Replies
Attached is a "Dome" type object (It's been shelled out).  I'm curious how I would calculate the Cubic Square Feet within this object.
Any input would be appreciated.
Thanks.
Thanks.
7 REPLIES 7
Message 2 of 8
3wood
3wood
Command: MASSPROP
Command: MASSPROP
Message 3 of 8
in reply to: 3wood
Hmmm... Locks up on me when I select my object... Then after I hit escape, it asks me if I want to "write data to a file".
I am using  a Mac.. Not sure if that means anything (no command line or ribbons)
Message 4 of 8
JDMather
JDMather
@c_scheer_2000 wrote:
... how I would calculate the Cubic Square Feet ....
What is "Cubic Square Feet"?
Message 5 of 8
JDMather
in reply to: JDMather
JDMather
If I fill the cavity volume with "water" and measure that I get -
Message 6 of 8
Kent1Cooper
Kent1Cooper
Another way is to get its "Volume" VLA property.  Paste into the Command: line:
(vl-load-com); [if the following line alone results in an unknown-function error message]
(vla-get-Volume (vlax-ename->vla-object (car (entsel "\nSelect Solid for its volume: "))))
That reports in cubic drawing units, so if those are inches, you'll have to divide the result by 12-cubed [the number of cubic inches in a cubic foot].
Kent Cooper, AIA
Kent Cooper, AIA
Message 7 of 8
3wood
3wood
I am sure there is a command line in Mac version. I saw it on my friend's Mac.
Try typing COMMANDLINE on your keyboard ans see what happens.
Message 8 of 8
I don't know where you live at but over here in the USA we only have square feet or cubic feet
AutoCAD Inside the Factory
