AutoCAD Forum
CADWorx - Edditing pipe and fitting connection
5 REPLIES 5
537 Views, 5 Replies
I have a problem with edditing/modifying pipe and fitting connections (the symbols are lost somewhere). I tried to use reasosiate command but that did not help. Have any of you had a similar problem and can help with the solution ? Thanks
5 REPLIES 5
imadHabash
Would you clarify more your issue please ?
Imad Habash
When connecting the pipes, I do not see any markings (like a cross in a circle ) on the ends of each element that would allow me to snap one piece to the another.
imadHabash
If you're asking for osnap marks .. then you have to turn it ON .. press F3 .
Imad Habash
in reply to: imadHabash
Unfortunately in that case it's not that. All the settings on the ribbon are set up correctly. I think it is worth to mention that when I am opening the model on the local mode everythink seems to be working ok but on the server mode problem occurs (then I am not able to connect with each other any pipe).
pendean
You will need to redirect your question to the CADWorx forums over here https://hexagonppm.com/support and https://hexagonppm.com/support/ppm-smart-community
Forma Design Contest
