AutoCAD Forum
CAD DWG TO PDF.PC3 MISSING REQUIRED PROPERTY
7 REPLIES 7
Message 2 of 8
662 Views, 7 Replies
CAD DWG TO PDF.PC3 MISSING REQUIRED PROPERTY error keeps coming up every time I plot. PDF files will not plot.
7 REPLIES 7
Message 1 of 8
Message 3 of 8
Tomislav.Golubovic
Does it work ok if you print it to a directory with a smaller path length?
Message 4 of 8
Yes it does work if i use Nitro PDF or if i print to physical printer, even though the error still comes up.
Message 5 of 8
Also if I create a new file called "DWG To PDF2.pc3" this works. However old file called "DWG To PDF.pc3" does not work.
Message 6 of 8
Tomislav.Golubovic
Is the PC3 the standard out of the box one?
Message 7 of 8
Valentin-WSP
@Anonymous ,
Welcome to the AutoCAD forum.
  1. Make sure your AutoCAD has all recent updates.
  2. Make sure to have the appropriate printer driver for AutoCAD.
Consider these suggestions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 8 of 8
jggerth
What version of AutoCAD?  Patch level?
Forma Design Contest
