AutoCAD Forum
by Block vs by Layer
1 REPLY 1
jmvogt1986
694 Views, 1 Reply
Hello again.
I am used to and prefer setting parameters like linetype/line weight/colour etc by Layer.
What use is the By layer option? I have never used it because I know that I do not understand blocks too well. I know how to draw and create blocks and that's it (excluding adding fields)
NB: this by layer/by block question also applies to layer properties manager
Can someone please enlighten me?
Many thanks 😊
1 REPLY 1
Gabriel_Watson
in reply to: jmvogt1986
I believe there was a typo in your question, and it is confusing us about when you refer to by layer and when you are talking about by block.
There is a similar thread answering some of the differences here:
https://forums.autodesk.com/t5/autocad-forum/bylayer-and-byblock/td-p/2691367
This reply has been edited by the moderation team as the link was no longer valid.
AutoCAD Inside the Factory
