Button size
Button size
id_11
Button size
id_11
I prefer to use Toolbars as per previous AutoCAD installations.
The stanbdard button size is too small, the option for larger is too large (in the sense that I can't fit them all in).
Is there a setting to have somewhere in between?
paullimapa
nothing in between but perhaps you may want to explorer changing your display resolution or even scaling it?
Paul Li
IT Specialist
@The Office
id_11
Thanks Paul, figured there may be something in between, since icons come in a range of sizes, like:
16x16, 24x24, 32x32, 48x48, etc. pixels
paullimapa
But with AutoCAD when you enter command CUI you'll see that it only supports two icon sizes:
Paul Li
IT Specialist
@The Office
id_11
OK fair enough, at least there is the 2 options then
paullimapa
you could always post this as a wish list item for autodesk
or post here: AutoCAD Wish List
Paul Li
IT Specialist
@The Office
