Bluebeam batch plotting trouble Acad 2025
JakCDDXM
Observer Observer
830 Vistas
14 Respuestas
Mensaje 1 de 15
JakCDDXM
Observer
Observer
Just upgraded from Acad 2022 to Acad 2025. For some reason the batch plot utility does not plot anything. here is the error I see under publish details:
@JakCDDXM - topic title has been adjusted for better clarity. (batch plotting trouble Acad 2025/Bluebeam batch plotting trouble Acad 2025)
0 Me gusta
831 Vistas
14 Respuestas
Respuestas (14)
Mensaje 2 de 15
paullimapa
Make sure you’ve installed update 2025.1.2
Paul Li
IT Specialist
@The Office
0 Me gusta
Mensaje 3 de 15
pendean
Community Legend
Community Legend
Did you forget to turn of background publishing? Looks like you are a candidate needing to do that like many of us.
0 Me gusta
Mensaje 4 de 15
JakCDDXM
Observer
Observer
It looks like we have the most current update installed.
0 Me gusta
Mensaje 5 de 15
JakCDDXM
Observer
Observer
background plotting and publishing are not currently enabled, background plotting is not checked in the plot dialog, and the backgroundplot variable is set to '0'.
0 Me gusta
Mensaje 6 de 15
paullimapa
perhaps with the upgrade installation the custom plot devices were not migrated over...I see these missing:
Have you tried manually plotting that file to see if it works?
Paul Li
IT Specialist
@The Office
0 Me gusta
Mensaje 7 de 15
JakCDDXM
Observer
Observer
yes, they plot fine individually. I'm using the 'publish to plotter named in page setup' setting as i always have. I'm using Bluebeam to plot individually and that setup in my files has always worked flawlessly. I've made new autocad files and setup new BB plotter setups to make sure it wasn't something saved into a 2022 .dwg, but that's not helped either.
0 Me gusta
Mensaje 8 de 15
paullimapa
To be sure enter at command prompt:
About
Then do a screenshot and share that here
Paul Li
IT Specialist
@The Office
0 Me gusta
Mensaje 9 de 15
paullimapa
Do a screenshot of each of the Plot window and then the Publish window. I would like to see if the page setup name “PDF” matches with what’s shown in your OP screenshot
Paul Li
IT Specialist
@The Office
0 Me gusta
Mensaje 10 de 15
pendean
Community Legend
Community Legend
@JakCDDXM You might need to reset your MECH2025/AutoCAD2025 back to defaults, then test without migrated content from the 2022 versions, to resolve this issue
0 Me gusta
Mensaje 11 de 15
baksconstructor
I assume you manually removed the printer.
AutoCAD PDF (General Documentation).pc3
Return it to its place
0 Me gusta
Mensaje 12 de 15
pendean
Community Legend
Community Legend
@JakCDDXM BlueBeam Support is over here
0 Me gusta
Mensaje 13 de 15
JakCDDXM
Observer
Observer
0 Me gusta
Mensaje 14 de 15
JakCDDXM
Observer
Observer
That may have done it. All my drawings plot with the bluebeam PDF printer/plotter, but when I select the saved PDF page setup from my pull down list, it switched to "none". Renaming my page setup appears to have fixed the issue. Cautiously optimistic.
0 Me gusta
Mensaje 15 de 15
paullimapa
Very good…cheers!!!
Paul Li
IT Specialist
@The Office
0 Me gusta
