AutoCAD Forum
Block name batch insertion
3 REPLIES 3
288 Views, 3 Replies
hi all.
I have a series of dxfs wich i insert in a dwg as blocks.
I want to know if there is a easy way to insert the block name in the middle of each block bounding box.
Thanks in advance .
3 REPLIES 3
leothebuilder
How about a field with block name?
in reply to: leothebuilder
How do i do it??.the goal was to automate the process . Is there a lisp somewhere to start with ??i want to do it one time after all the blocks(dxf) insertions ??
Kent1Cooper
@AsramiOsram wrote:
I want to know if there is a easy way to insert the block name in the middle of each block bounding box. ....
There's a routine called LabelBlockUnder.lsp here that does it under Blocks.  [There are also other suggestions on that thread.]  Search it for all instances of "Your" as part of a term, and give it appropriate content.  I think it should do what you're asking if you replace its Text-command function with this:
(command
  "_.text"
  "_mc"
  (mapcar '/ (mapcar '+ (vlax-safearray->list minpt) (vlax-safearray->list maxpt)) '(2 2 2))
    ;; [above line calculates middle of bounding box]
  "" ; omit this line if YourTextStyle has fixed height
  0
  (vlax-get blockobj 'Name)
); command
Kent Cooper, AIA
AutoCAD Inside the Factory
