Hi
I was trying to create block with attributes and I have assigned the default values. I tried to insert the blocks into a new dwg file but all the attributes are lost. However, when I copy the block to the new dwg, I can use without any issue. I am using Windows 7 with Autocad 2013. Can anyone help me in this regard?
Hi
I tired and when I select the block, it says "the selected block has no attributes". Besides, error message shows as "Error selecting entity".
Seems like there's some kind of corruption happening with this block. Have you tried running AUDIT on the file? Do you mind posting the file here, we can have a look at it for you.
There doesn't seem to be any issues with the block attributes in the file when I open it. See screenshot attached.
Have you tried inserting the block? The block itself has no issue and same with copying. The only issue I had was when I tried to insert it into another drawing, the attributes were gone.
Yes, inserting and copying to another file doesn't cause any issues neither. I'm not sure what maybe causing the issue.
I've saved the block into it's own work block, you just need to insert it directly into a file with the INSERT command. See if it fixes the issue for you.
