Blank page when plot preview & export to pdf
This widget could not be displayed.
Hey,
Excuse my awkwardness but I'm self taught on AutoCAD & have managed fine for last few months but have encountered an issue this evening I can't resolve.  I've produced drawings, basic they may be, but when preview them the actual drawing area is barely noticable & when export to pdf it practically prints a blank page.  I have very simple items in drawing, stockpiles, excavations test locations, and have been producing pdf's fine, even as recently as this morning using the same cadfile.  But what ever I've managed to do since then has changed something and I can't resolve the issue.  Any help would be greatly appreciated.
Replies (56)
I afraid your suggestions are not working. Please open my file and try to print it to pdf(in A1 size), you will know what i mean.
Alfred.NESWADBA
Maybe I missed something in the posts before, but "open the file and try to print" ... works on my system.
Please look to the attached video.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Sorry Alfred, did you received my previous reply?
Alfred.NESWADBA
Which of the replies are you referring to? The one that states "I afraid your suggestions are not working. Please open my file and try to print it to pdf(in A1 size)"?
That's exactly what I did (...please open my file and try to print...) and what I showed in my video, for me it is working (with the correct layout settings) and up to now I don't exactly know what is not working on your side (follow my steps in the video, what is different on your system?)
- alfred -
Alfred NESWADBA
It is working now after i remove one of the xref. Sorry to trouble you.
Benzcl55
I currently use Acad 2020and I am having the same PDF Plot preview not showing anything, it will show up in Bluebeam after the PDF is produced, but plot preview will just show a blank page!! Ive followed the instructions st set up my page, but no luck!!
@Alfred.NESWADBA wrote:
Just guessing:
a) don't set your print area to "Extents", use "Layout" instead (in the plot dialog)
b) turn off "plot transparency" (in the plot dialog)
c) start layer manager and verify that no layer is set to "no plot"
d) if you want a PDF, then don't use the Brother printer, use the "DWG to PDF.pc3" as printer/plotter.
If nothing helps then try to upload the drawing, might help us if we can look into it.
HTH, - alfred -
Just guessing:
a) don't set your printarea to "Extents", use "Layout" instead (in the plot dialog)
c) start layermanager and verify that no layer is set to "no plot"
HTH, - alfred -
Alfred.NESWADBA
Please upload the dwg-file (and all referenced files, best would be to use command _ETRANSMIT) so we can test this on our systems.
Just to make sure ... you are using an AutoCAD PDF plot device like "DWG to PDF.pc3" or "AutoCAD PDF (General Documentation).pc3" and not any 3rd party device?
- alfred -
Alfred NESWADBA
Hello Alfred,
Can you help with my file? I am trying to plot, but it gave me blank output. I tried everything, but still it gave me blank output, will really appreciate if you can help me. I've attached the .dwg file. Hope u can look into it.
Thanks.
S.Faris
Select Extents under What to Plot option in Plot Dialog
SALMANUL FARIS
omg lol, that worked perfectly, I dont know what I did wrong just now. Thanks man for the help!
Blank page when export to pdf. i don't know how to fix it T.T
Hi All,
 We already figured it out.
It turned out simply that the model scale was too big on a sheet of paper.
And so it is basically beyond the sheet borders.
And if you zoom out slightly, you will see the model.
So, simply change the scale and everything will become normal.
Tell everyone about it.
Pretty weird though it is happening in Revit only. No other software witnessed such an event.
Thank you for help me out! 😁
hakankaras81
Community Visitor
Community Visitor
open layers page, and check if the print option of all layers are open
LAWRENCEALIBUYOG
Community Visitor
Community Visitor
Hello Alfred, Everyone,
Can someone help me with my AutoCAD. Every time I save my 3D model in pdf file. My drawing always multiplies some are broken image. But the PDF itself is accessible. See attached file. Please someone help me.
Attached photo in AutoCAD preview.
dmfrazier
It looks like you are plotting a Layout that has multiple viewports.
Show us images of the two Layout tabs, please.
(Note: In general, it's better to start a new discussion topic instead of continuing a discussion on a different topic that began in 2013 and is marked as solved.)
papsmureithi20
Community Visitor
Community Visitor
Works like a charm. Thank you
