AutoCAD Forum
BIM 360 Toolbar in 2019
3 REPLIES 3
593 Views, 3 Replies
Hello it seems that i lost my BIM 360 Toolbars from 2018 version, i have tried uninstalling and reinstalling and i still do not see it.
bim360_Attach and Glue Commands work but no Toolbar.
3 REPLIES 3
pendean
pendean
Community Legend
Community Legend
CUILOAD command, is BIM360 listed?
CUI command, Ribbon and Toolbars Sections, is it in there?
Did you try and select a different workspace then back to your default to see if it appears?
in reply to: pendean
I see CUI Commands but no Toolbar, after trying the workspaces migrated from 2018 it does show them! Just not in 2019.
pendean
pendean
Community Legend
Community Legend
AFAIK you cannot migrate that add-in from 2018 to 2019, it needs to be deliberately installed for 2019 only.
Your migration probably added more funk than help into 2019 as well, if that is the case you will need to reset 2019 to defaults and manually set up 2019.
AutoCAD Inside the Factory
