AutoCAD Forum
Best PDF to DWG converter
69 REPLIES 69
Message 1 of 70
tahdesign1
581590 Views, 69 Replies
I have been ask to supply a PDF to DWG converter on our CAD network.
I wanted to ask around for what others are using for this and which might be the best one out there.
So what are you using if you are doing this? There seems to be many to pick from.
69 REPLIES 69
Message 61 of 70
Hi @sellvakumarmech,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 62 of 70
Hi John,
           I Believe, there is an option to remove layers using acrobat. I am also using older version of acrobat, If i wanna move new version of acrobat there are some issues to get licence...once i done, i will share my knowledge with you ASAP.
Kind regards,
Sellvakumar
Message 63 of 70
John,
           Very thank you for your guidance. It was working. its help to done my job quickly.
Sellvakumar
Message 64 of 70
in reply to: TerryDotson
The DotSoft program created the cleanest drawing BY FAR!!  I have tried a number of conversion programs, including those from AutoDWG.com and Able2Extract.  I am very impressed with DotSoft's PDF2DWG.  I compared each of the programs using the same PDF file, which was rather complex and created by a relatively unknown illustration program.
Comparing each of the converted drawings, the curved edges of circles and other objects were very smooth with the DotSoft PDF2DWG, not jagged and disproportional like the others.  It produces the proper line weights and original colors of the PDF, which were mandatory requirements for my project.  We have many estimators and anticipate using DotSoft PDF2DWG on all of our conversion applications.  It is very reasonably price for the quality it produces.  I am not affiliated with DotSoft, but I am a very satisfied customer.  http://www.dotsoft.com/pdf2dwg.htm
Tags (2)
Message 65 of 70
Alfred.NESWADBA
Which ones?
And most important: have you tried the AutoCAD internal PDF-import?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 66 of 70
rkmcswain
SureVoid wrote:
The DotSoft program created the cleanest drawing BY FAR!! ......I am not affiliated with DotSoft, but I am a very satisfied customer. http://www.dotsoft.com/pdf2dwg.htm
I've always been a supporter of Dotsoft products, but since I'm no longer a daily user of CAD, I don't get to use/test tools like this as much as I'd like. Good to know it works great!
R.K. McSwain     | CADpanacea | on twitter
Message 67 of 70
rkmcswain
in reply to: tahdesign1
I'd be very interested to know why this (PDF to DWG) is such a a big thing? I can see the occasional PDF of maybe a detail, but it seems like there are so many people with this need. Where is the DWG file from which the PDF was made? Are people losing DWG files, but somehow managing to keep the PDFs? Are people sending others PDFs instead of DWG files, and the PDF recipient is trying to salvage a DWG out of it?
I'm just curious how often you need to do this and why?
Message 68 of 70
in reply to: rkmcswain
I am with a Sub-Contract company as of the moment and I do all the Submittal drawings. Receiving the DWG file of the job makes the turn-a-round process faster but at times there are firms or contractors that will not release the DWG files. So, The PDF file of the job/Project is all we receive. In this case a converter helps with submitting a drawing of their building elevation and roof plans quicker.
Message 69 of 70
I'm not very familiar with AutoCAD, and I don't have a lot of time to learn it.  We have been using another software package for many years that works great for our needs.  We sometimes need to supply engineers with DWG files for incorporation into their work.  Our program creates DWG files, but they are not very good by comparison.  We have determined that creating PDF files and converting to DWG using DotSoft's PDF2DWG program gives us the best results.
Message 70 of 70
teimat
Please stay away from Scan2Cad.   They sell software they claim converts every pdf to dwg.  After it fails they try to up charge you for a higher version rather than make good and give you a refund.
AutoCAD Inside the Factory
