AutoCAD Forum
Batch Export to DGN
5 REPLIES 5
1053 Views, 5 Replies
Batch Export to DGN
Other than writing a script file, is there a way to batch Export a directory of DWG files to Microstation DGN? I thought AutoCAD Trueview did that…but looking at documentation….doesnt appear to be the case.
Batch Export to DGN
5 REPLIES 5
pendean
pendean
Community Legend
Community Legend
You'll need to purchase a third party converter that will do that: Gogle Search offered a few when I looked it up.
cadwomen
in reply to: pendean
cadwomen
Hy
way a  a third party converter ??? i see no reason for ? ACAD 2013 LT did it .
the only thing you need will be a windows script or simuler that collect all the files and made a *.scr file for you , you start the run and make a coffee break
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Hy
cu cw
pendean
in reply to: cadwomen
pendean
Community Legend
Community Legend
So you didn;t read the first part of the OP's post, did you 🙂
"Other than writing a script file,"
cadwomen
cadwomen
Point for you , i missd that part Smiley Surprised
but what are the reasion for / or the problem not to use a script ? its free and no athier software in use ?
cu cw
cu cw
Hey CW,
I know it is a bit old post, but...
New to scripting. Do you mind share your knowledge - how the script would look like. I have more than 300 files to convert from dwg to dgn and doing it manually would be painful. 🙂
Milos
Hey CW,
Milos
AutoCAD Inside the Factory
