BASE VIEW ISSUE
BASE VIEW ISSUE
Message 1 of 10
BASE VIEW ISSUE
I Have an imported model which I am selecting a few 3D bodies in BASE view,
when the BASE view is projected to an isometric a HUGE elipse circle appears right through the view,
any ideas how to remove this?
I have attached the drawing, the error is shown on layout 3
George Abbott
Replies (9)
Message 2 of 10
john.vellek
HI @Anonymous,
I am afraid your attachment did not stick. Can you try again perhaps using a different browser? From your description, this is something I don't believe I have seen before.  Please tell me your AutoCAD version too so I can use the same to test your file.
John Vellek
Message 3 of 10
i think the model is attached now.
i have also attached a PDF which shows you a screen shot of the issue.
thanks
Message 4 of 10
thanks
Message 5 of 10
I forgot to mention, the model is AutoCAD 2018
Message 6 of 10
john.vellek
HI @Anonymous,
I copy/pasted your geometry into a new drawing.  Then, I moved all the geometry close to 0,0 as your original location was extremely far away form this origin.  When I project the views they now show up correctly. Can you try this too and let me know if it works for you too?
John Vellek
Message 7 of 10
John,
I used CTRL+C and then CTRL+V into a new drawing and then insertion point 0,0, the error still occurred.
is this the correct process?
Message 8 of 10
john.vellek
Hi @Anonymous
That sounds right but I noticed that your model is still a block so I exploded it and then everything projects properly.  I have attached my file for you to try as well.
John Vellek
Message 9 of 10
john.vellek
Hi @Anonymous
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 10 of 10
Hi John,
sorry i have been out of office today.
this issue was resolved.
thanks
