Base View From Model Space not working
mto070
Message 1 of 22
mto070
I have an issue with the "Base View From Model Space" function when i try to make 2D technical drwaings in templates.
When i have a solid 3D object on the model board and activate the function in the "Layout" panel in the template - nothing happens and the command bar shows the "Move" function instead. When i look at the "F2" history it says that the "Inventor Server Failed to Load" and it goes to the move funtion instead.
I have googled the problem and others seem to have the same issue when they have older versions installed. However, I am running the latest version, and I have both tried to "Repair" and uninstall my AutoCAD, but it has not worked so far...
I am running AutoCAD 2020 Student Version on Windows 10. I don't know if i am the one doing something wrong here or if it is a bug... I am fairly new to AutoCAD.
Uploaded some screen shots. I would appreciate some help! 🙂
Replies (21)
Message 21 of 22
Konard_adamsMDGVJ
Worked. Thank you!
Message 22 of 22
mariustipa
In a very short time those garbages will not work at all anymore. Amazing how they distroy every software.
