BASE command help
BASE command help
Message 1 of 22
BASE command help
Im using AutoCAD R2015 English. When I try and use the command BASE (in Layout with no viewport and only one layer) to display orthographic views of my solid model drawn in model space, it fails.
I click on the BASE command and select 'from Model Space' the MOVE command appears in the command line. If I click on the BASE command and select 'from Inventor' the FILLET command appears in the command line.
Is this a known problem or am I doing something wrong?
Replies (21)
Message 2 of 22
john.vellek
Hi @Anonymous
This is strange behavior.  Is the model itself native to AutoCAD or did it start in another program such as Inventor?
If you type Viewbase and select from model does it behave differently?  I assume you are working in AutoCAD 2015 for Windows as the Mac version does not include this feature.  The command Base is for setting the location of the UCS. Is that what might be causing some confusion?
Is your AutoCAD 2015 fully updated from here?
What is your OS?
John Vellek
Message 3 of 22
Hi John,
Many thanks for your reply
In reply to your questions
* The model was native, it did not start from Inventor or any other
* Fully updated is a good question. Initial loading only has not had
any updates
* OS Windows 7
* When I type in Viewbase at the command line and return it goes
nowhere but does add 'Inventor Server failed to load.'
Hope this helps
Clive
Message 4 of 22
maxim_k
Hi John,
You are posting in wrong place. This is AutoCASD for Mac Forum, but you are using AutoCAD for Windows.
Please post your questions here:
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
Anyway, trying to answer your question here:
VIEWABLE (if you mean it) command works only in Model layout.
Do you use 32-bit or 64-bit AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 22
GrantsPirate
Maybe this will help
https://forums.autodesk.com/t5/autocad-forum/viewbase-inventor-server-failed-to-load/td-p/4553531
And if not search the internet for
inventor server failed to load
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 22
john.vellek
HI Maxim - Thanks for the catch.  I suspected that the customer was using the Windows version but the question was posted in the Mac forum.  I have moved it now to the AutoCAD forum so that the customer might receive more appropriate suggestions.
Thanks!
John Vellek
Message 7 of 22
Kent1Cooper
[In case others are confused as I was, this is about the Ribbon's Home tab / View panel / so-called "Base" icon, which is actually about the VIEWBASE command, not the BASE command -- the latter is a command name, and is about something entirely different, so I think they've created a contradiction in the setup of that item.]
Kent Cooper, AIA
Message 8 of 22
maxim_k
From the first OP's Post it is clear that when he click on Viewbase button on the Ribbon and select one of two options, AutoCAD takes only "options" part of the command. As the result it calls Fillet command (for F option) and Move command (for M option) of VIEWBASE command.
There should be something wrong with main CUI file as I think.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 22
john.vellek
Hi @Anonymous,
Is it possible to attach your drawing to a post so I can take a look?  If it is prompting the Inventor failed then there is something wrong with the model.
IF you are also seeing other command pop up then I suggest typing CUI and then rt-clicking on the ACAD menu and resetting the CUI.
John Vellek
Message 10 of 22
Many thanks for your help
Ive attached a typical 3D solid model which when I try and use Base
(from Model Space) the MOVE command is loaded. My OS is Windows7 62bit.
I tried to load R2015 updates as suggested but it refused saying I have
an AutoCAD English version.
Hope this helps
Clive
Message 11 of 22
maxim_k
Hi Clive,
There is no 62-bit Windows, only 32-bit or 64-bit. I asked about this because VIEWBASE command only available in 64-bit AutoCAD version.
So I'm asking one more time:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 22
Sorry 64bit
Cheers
Message 13 of 22
maxim_k
64-bit- AutoCAD or Windows?
Can you post screenshot of the"About AutoCAD " window?
Just want to be sure.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 22
TheCADWhisperer
@Anonymous wrote:
1. Ive attached a typical 3D solid model
2. which when I try and use Base (from Model Space)
3. I tried to load R2015 updates as suggested but it refused saying I have an AutoCAD English version.
1. No file attached here.  Are you using web browser to respond or are you using phone?
2. Viewbase, not Base and PaperSpace not ModelSpace.
3. Post image of this download.
2015 Service Pack 2
Message 15 of 22
Hi
I am using paper space. Were I mentioned (from Model Space) this is the
prompt when clicking on the BASE command.
Please find attached a trial 3D Model which when you go into the BASE
command the MOVE command is loaded.
Many thanks
Clive
Message 16 of 22
maxim_k
Hi Clive,
Again - no file attached 😞
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 22
Hi
Another try
Message 18 of 22
maxim_k
Nothing.
Are you using browser or you reply via e-mail?
Try to use browser.
After you choose file to attach, ensure it is in attachments:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 22
Hi
Via email
Clive
Message 20 of 22
maxim_k
Hi Clive,
If you want to attach drawing, then you should use browser for reply.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
