.bak files sorting before .dwg files..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This annonying problem cropped up before in 2014.. For some reason the .bak files appear before the .dwg files. Sorting by Type is a short term solution, but then the dwg files are reversed from last alphabetical to first, and then the .bak files.
The solution that worked before was to right-click on an AutoCAD file, and use "open with" and then select AutoCAD 2014. However, that is not working this time with AutoCAD 2016
Another solution was to go into Windows Explorer options and select "Sort by Groups", but I don't see that option.
Is there some other solution? The only thing that I can think of doing is to use MOVEBAK, however other people in the office might not find the folder or understand that it has been moved.
Sort of odd that there isn't better coordination between AutoCAD and Windows Explorer.. Is there another Explorer type system I can download to view files that has better control.
thanks!
Autocadding
