AutoCAD Forum
bak files in another folder
2 REPLIES 2
Rikkes
1058 Views, 2 Replies
Isn't it possible to safe the bak files (not the autosave ones) into a sepparate folder instead of the same one as the original drawing?
Or, if not, to create only a bak file with the autosaves and not with the normal drawing?
Or, make the bak files invisible?
Problem is that there are so much bak files in my working folders.
Thx
Rikkes
2 REPLIES 2
in reply to: Rikkes
Type MOVEBAK, then the folder where you want the BAK files to be saved to.
in reply to: Rikkes
Also, to turn the BAK file creation off type ISAVEBAK and set it to 0.
AutoCAD Inside the Factory
