When i'm saving my .DWG file he save an .BAK file automatically... i don't know why, don't hanve any problem with my AutoCAD , it's school project i'm opening and it does it each time
Solved by GrantsPirate. Go to Solution.
AuotCAD does that by default. It can be turned off, I have never used it, but most swear by it in case your file becomes corrupt.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
>> ok so each time i will save my work it will do a .BAK file?
Yes.
- alfred -
Yes.
But - to avoid misunderstandings - it doesn't create each time a new additional bak-file. The one existing bak-file is always overwritten.
So you have ONE file to restore the previous (last saved) state. (Beside the sv$-file, created automatically in predefined time intervals. That's another filetype to avoid losing your work).
cadder
Jürgen Palme
