AutoCAD Forum
Avoid plotting duplicate objects
3 REPLIES 3
Darwin33
399 Views, 3 Replies
Is there a way to avoid that autocad plot duplicate objects. It seems that the order erase duplicate objects have some kind of bug bcz it doesnt work properly.
Better than that is there a safe way to erase all duplicate objects when you finish a drawing?
Best regards
3 REPLIES 3
in reply to: Darwin33
Dear Mr. Darwin33
I guess "OVERKILL" command can do your job.
Hope this could help you  out.
Regards
DMC
imadHabash
Is there a way to avoid that autocad plot duplicate objects >>>> NO there is not.
It seems that the order erase duplicate objects have some kind of bug bcz it doesnt work properly. >>>> Erase command is made for deleting any thing selected even duplicated objects which appeared when you select the objects more than one.
... is there a safe way to erase all duplicate objects when you finish a drawing.>>>> OVERKILL command can do that BUT you have to be careful when you use it and you have to know and understand how to fill the dialog if needed.
Good Luck..
Imad Habash
jggerth
Under your plotter setup, chose the 'Lines Overwrite' option, and only the topmost segments will be plotted.  Lines merge will let both the underlying and overlaying linework be plotted.
With modern laser/inkjet plotters, I don't think that duplicate linework get plotted -- unless you're still using an old-school pen plotter?
AutoCAD Inside the Factory
