Automatic Leader Number Increment or Decrement Command
rajugundu157
rajugundu157
I want to increase or decrease the Leader numbers like below images
vladimir_michl
If the fixed part of the leader text is "static" (always the same), you can use the TCOUNT command (in Express Tools) or the IncText utility:
https://www.cadforum.cz/en/free-text-counter-autolisp-utility-tip8654
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
Simon_Mathews
i use a lisp called "gile increment" , this will sort blocks or text in ascending or descending order . very helpful lisp when you got lots to order incremently
https://apps.autodesk.com/ACD/en/Detail/Index?id=8051485828049059617&appLang=en&os=Win32_64
nehakakar
I’d like to add that using the TCOUNT command is a quick way to handle numbering. Also, tools like the 'gile increment' Lisp can be great for managing text or blocks in ascending or descending order. Both methods seem efficient for this task.
