AUTOLISP or Other Way of Testing for Matching
Message 1 of 8
Hi - i frequently have to check for matching between various designs of roadways and similar things.  I have to painstakingly zoom in then measure between the new and old drawing to see how well it matches, is there a more automatic way of testing for this?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
I would use XRef to place one drawing under the old one, set the layer colors to make it easy to identify which geometry is version 1 and which is version 2.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
Thanks, that's a good idea, however I am also looking for some kind of automatic method of testing how close lines are matching, some type of use perhaps of the OVERKILL command, but in a more automatic way?  any kind of lisp routine? anything?
Message 4 of 8
pendean
Community Legend
Community Legend
No, that's a destructive method of checking files. if that is not the intent, XREF one file into the other, control the colors of the "good" file for contrast, set DRAWORDER correctly and the differences should really pop visually.
Message 5 of 8
3wood
There are some commercial add-ins avaiable around web which allow you compare new and old versions and shows changes with different colors.
It helps you spot out the changes but you have to create the change detail report manually.
Message 6 of 8
cadwomen
Hy
not automatic but work use the DWF Format there you are able to check it
http://usa.autodesk.com/design-review/
some vid on YT
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Message 7 of 8
Wish I had an Easy Button to do my job....
Message 8 of 8
ВeekeeCZ
From AutoDesk and free...
https://apps.autodesk.com/ACD/Detail/Index?id=appstore.exchange.autodesk.com%3Adwgcompare%3Aen
