AutoCAD Forum
Autodesk Certified Professional
11 REPLIES 11
Message 1 of 12
1085 Views, 11 Replies
Hi Everyone,
I completed ACP exam.  I received a badge from Acclaim.  How do i down load the certification and print it.  I would like to frame it with my other certifications.  Anyone know how to print the certification.  I used PearsonVue to take the exam.
Thanks!!
Robert
11 REPLIES 11
Message 2 of 12
pendean
Ask the folks that administered the exam.
Message 3 of 12
in reply to: pendean
Thanks for quick response, I guess no one does.  Its all good I will figure it out,
Thanks!!
Robert
Message 4 of 12
 Did you find the way to download the Autodesk Certified Professtional Certificate? Please share it to me.
Message 5 of 12
Hi, did you able to download the Certificate? i passed also using Pearson vue and i dont know how to get my Certificate
Message 6 of 12
Hi Robert,
Do you able to receive your Autodesk Ceritifcation?
Message 7 of 12
Grover_Puma
Have you been able to solve the certificate problem?
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Message 8 of 12
Grover_Puma
@Anonymous  Have you been able to solve the certificate problem?
Saludos!
Message 9 of 12
in reply to: Grover_Puma
@Grover_Puma  yes i already download my certificate at Acclaim website. in the Share dialog box
Message 10 of 12
Grover_Puma
@Anonymous Can you share how I solve this problem?
Saludos!
Message 11 of 12
@Grover_Puma You should be able to download a digital PDF certificate along with claiming your digital badge from Acclaim. You should have received an email from Acclaim following your exam with instructions for signing-up or signing-in to your Acclaim account. When you sign in, you should see your digital badges on your account dashboard. First click on each badge to see the details for that digital badge. If you then click on the blue “Share” button you should be taken to a window that lets you choose how to share (see below). Selecting the “print” icon on the far right, will provide you with a button to download a PDF of your certificate.
Message 12 of 12
Grover_Puma
@Anonymous Thanks
Saludos!
AutoCAD Inside the Factory
