Hi Everyone,
I completed ACP exam. I received a badge from Acclaim. How do i down load the certification and print it. I would like to frame it with my other certifications. Anyone know how to print the certification. I used PearsonVue to take the exam.
Thanks!!
Robert
Solved by pendean. Go to Solution.
Did you find the way to download the Autodesk Certified Professtional Certificate? Please share it to me.
Hi, did you able to download the Certificate? i passed also using Pearson vue and i dont know how to get my Certificate
Have you been able to solve the certificate problem?
@Anonymous Have you been able to solve the certificate problem?
@Grover_Puma yes i already download my certificate at Acclaim website. in the Share dialog box
@Anonymous Can you share how I solve this problem?
@Grover_Puma You should be able to download a digital PDF certificate along with claiming your digital badge from Acclaim. You should have received an email from Acclaim following your exam with instructions for signing-up or signing-in to your Acclaim account. When you sign in, you should see your digital badges on your account dashboard. First click on each badge to see the details for that digital badge. If you then click on the blue “Share” button you should be taken to a window that lets you choose how to share (see below). Selecting the “print” icon on the far right, will provide you with a button to download a PDF of your certificate.
@Anonymous Thanks
