Autocad2016 3D ''Hidden'' line problem
Message 1 of 13
hi,
I am trying to use the visual style ''Hidden'' in my 3D model drawing, then I plotted in PDF. In the drawing, there are some thick black lines around ( the picture below). I would like to have the same thickness in my drawing, is there any way I can change it? Thank You.
Replies (12)
Message 2 of 13
Plotting with CTB or STB??  Visible lines lineweights in hidden views are controlled the same way they are in any other plot.
Message 3 of 13
Alfred.NESWADBA
Try the following steps:
  • In the layout/paperspace select your viewport
  • In property window set the property "Shade Plot" to "Legacy Hidden"
Does that work better?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 13
hi Alfred,
      after i changed the 'Legacy Hidden', the drawing is a bit different..haha.. not sure is it my process have some problem...
Message 5 of 13
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you attach your drawing and CTB file? I would like to get this working properly for you.
John Vellek
Message 6 of 13
GrantsPirate
I would go into visual styles and for that style set Silhouette Edges show to no.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 7 of 13
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 8 of 13
Hi, I would like ask how to export the file in CTB? Because my CAD file is too big and it couldn't upload in here.Thank You.
Message 9 of 13
Message 10 of 13
john.vellek
HI @Anonymous,
I suggest you eTransmit your file and it will end up in a ZIP file. You should be able to attach a fairly large one on a post without any issues.
John Vellek
Message 11 of 13
leeminardi
Rather than using the visualstyle hidden, try using 2D Wireframe instead but first set DISPSILH to 1. With 2D Wireframe active  give the HIDE command.  To get better resolution for curves change the Render Object Smoothness value in Options from 0.5 to 2.0 or greater.  Then make your pdf plot.
~Lee
lee.minardi
Message 12 of 13
sorry for the late reply, I have attached the DWG. drawing file. Thank You.
Message 13 of 13
john.vellek
Hi @Anonymous,
I went into the Visual Styles Manger and selected Hidden. I scrolled down to the Silhouette Edges and changed the Show to No.
Now when I plot, all the lines are the same weight. is this what you are seeking to produce?
John Vellek
