Batch plot override
Hello Folks,
Hoping someone can help resolve an issue with batch plot overrides. This issue appears to be an issue in AutoCAD 2016, and not 2015.
We’re currently using AutoCAD 2016 to batch plot several files. We prefer plotting to “ADOBE PDF”, which has been the standard with the firm for several years. But when using the Batch Plot, the Plot Device has been set to Override: DWG to PDF, which results in lighter/thinner lines.
Is there a way override the override (aside from reverting back to AutoCAD 2015)
We have tried using a sheet set dsts set to several other printers, but the “Override: DWG to PDF” tends to stick, resulting in lighter lines.
We have tried importing dwts set to several other printers through the Page Setup drop-down in Batch Plot/Publish, but the “Override: DWG to PDF” tends to stick, resulting in lighter lines.
Plotting sheets individually, or Publish to: Plotter named in Page Setup seems to work, but both require more time and/or attention. And prefer not to to revert back to AutoCAD 2015 to perform Batch plots.
Is there an alternative method to get a desired plotter (Adobe PDF) rather than the Override (DWG to PDF), or is there a step that is missing?
Thank you for any clarification you are able to provide!
Screenshots can be posted if needed.
