AutoCAD Forum
AutoCAD - Why a step of DGN underlay deletion required before importing DGN ?
1 REPLY 1
timelapse1029
250 Views, 1 Reply
Hi all, I hope all is well with you !
I'm learning about DGN import.
According to the lecture video and practice exercise as well, there is a step of attaching DGN through X-ref, delete the underlay model, and then import the same DGN file via Insert tap -> DGN Import.
I tried just importing DGN without X-refing and deleting the underlay.
The end result is the same ! Is that right ?
Apparently it looks the same to me, and especially, the X-ref palette states that attached DGN is unreferenced.
How can I correct this unreferenced error if it is always an absolution to X-refing DGN as attachment and importing it ?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
1 REPLY 1
TheCADnoob
in reply to: timelapse1029
Without knowing the material you are referencing I'm not certain i can help.
CADnoob
Forma Design Contest
AutoCAD Beta
