Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
AutoCAD - when line crosses another line autocad attaches them together
hits4200
hits4200
for example if i draw a circle and then draw a line from the center of the circle outwards past the edge then autocad connects them together. i cant move them independently of each other. Any help would be appreciated.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
pendean
Community Legend
Community Legend
Share that DWG file with the line/circle that are permanently attached please, lets see your work for ourselves to try and help you decipher it.
hits4200
Thank you Pendean appreciate your time. The circle and the line are not connected but if you select just the line it moves the circle to. Just cant figure this one out.
RSomppi
I cannot recreate your issue but have you tried setting FSMODE to 0?
hits4200
yes, it is off. this is a weird one not doubt.
pendean
Community Legend
Community Legend
Here is your issue
You need to remove the Parametric Constraints you turned on https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-t...
hits4200
Thank you so much!!!!!!! constraintinfer value set was set to 1. Put it on 0 and solved the problem.
