AutoCAD Idea for Discussion
When using model views in View Manager you cannot change the Annotation scale of the view once you have created the view. This is annoying when using annotative scales & named views because every time you switch to an named view it rests the scale to the scale of the view. Please can AutoDesk/AutoCAD consider adding the function of editing the annotation scale of named view once they have been created in future releases of AutoCAD. It would improve productivity & seems like a simple change (I could be wrong...).
Excelent Idea, you should´ve post it like such
Thanks, I've added it to the AutoCAD 360 Ideas, hope this was the right place for it..?
https://forums.autodesk.com/t5/autocad-360-ideas/autocad-view-manager-amp-annotation-scale-idea
is this possible yet?
nop
