Announcements
sweep problem
sweep problem
hello
i am trying to draw the PC cable with diameter 45mm.
that cable has to sweep not only in X direction but also in Z direction
i attached the file data
i can only sweep in only one direction
help me pease
Replies (7)
Alfred.NESWADBA
In case your base geometry would not have arcs you could create a 3D-Polyline that has the 3D coordinates of your views, and then use this new object to sweep a circle.
The problem arises with 3D-Arcs as 3D-Polylines can't have arcs. So for your job I would create the cable in peaces, a straight cylinder and the bends as sweeps of just the arcs you have now. Then move these objects together and UNION them.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
thank you so much for your reply
i couldn`t imagine about the commands you said above
i am so sorry would you like to attach the file data?
thank you so much
j.palmeL29YX
Here a video, how I would do this.
In short words:
First you need the 3D-Path. To get it, I moved the given front view path and the top view path together and extruded they to 2 perpendicular surfaces. The 3D-Path is now the intersection of this 2 surfaces. Because this path includes lines and arcs, the inters command creates a spline (a 3DPolyline cannot include arcs).
Last you can place a circle at the end of this path and sweep it.
If you need more explanation fell free to ask again.
cadder
Jürgen Palme
Alfred.NESWADBA
@j.palmeL29YX
cool, really the better solution than my suggestion!
- alfred -
Alfred NESWADBA
thank you so much for your answer
i will be helped
i can draw a pc cable according to your videofile
but the one thing is that the path i draw is not a spline
is there anyproblem?
thank you so much Sir
thank you so much for your coorparation Sir
sorry Sir
thats my mistake
i can make a spline now too
thank you so much
