AutoCAD Update Version
FELIXJMELO
FELIXJMELO
How to know the installed AutoCAD version for updates.
Example, I have AutoCAD 2020 and I know there is already 2020.1.4 for download, how can I know the 2020.x.x installed?
rkmcswain
Run the ABOUT command.
BeKirra
Or you may click the button on top right corner of the screen.
I believe yours would be similar to mine.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
