AutoCAD - Thousand separator in Coordinate field
Message 1 of 16
I have created a block which when placed shows the X- and Y-coordinates of the block cross-hair, according to:
The problem is that I want these numbers to be separated by the thousands...
I have found the option for changing it in the FIELD menu, but unfortunately it's marked grey, according to:
Is there an easy way around this?
[The subject line of this post has been edited for better findability by @handjonathan Original: Thousand separator in Coordinate field ]
Replies (15)
Message 2 of 16
cadffm
Your field value is not ONE number,
You can create 3 separate field for X X Z,
Sebastian
Message 3 of 16
imadHabash
i suggest to change FIELDDISPLAY value = 0 .
Imad Habash
Message 4 of 16
I have created on field for X, and one for Y. They are shown separately if you look at my pictures.
Message 5 of 16
Thank you for the response, but this only removes the highlight of the field. I still cant change the thousand separator for the coordinate in the Field options.
Message 6 of 16
Alfred.NESWADBA
you can take the insertion X value as formula and then you can use the result as number with thousands separator...
May be this video helps you to get this done!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 7 of 16
cadffm
Thats what i also wanted, but it isn't working!
The field value comes as X,Y,Z into the formular field?
The problem was my ARCHITECTURE style for length units, sorry.
We are on the right way, just my current setting was wrong.
Offtopic: You don't need to copy the fieldcode, you can create your field inside the formular editor directly
Sebastian
Message 8 of 16
cadffm
The way via format field and *1000 shorts your number, so it isn't the same but for usual it is what users really want,
you too?
field
1234.33 => 1.23433
The other option you are looking for just add a point on the thousand
1234,33 => 1.234,33
Sebastian
Message 9 of 16
ВeekeeCZ
Alfred's solution works perfectly.
Message 10 of 16
cadffm
for you https://recordit.co/q28AYLUDRj
Sebastian
Message 11 of 16
psilvavieira
Great idea! Works perfectly.
Message 12 of 16
cwtwong
It's very helpful. Thank you!
Message 13 of 16
VRUSHABH.JOSHI
Please share video link again
I want to display point coordinates in M instead of mm
Message 14 of 16
cadffm
Alfreds link is valid and working,
also my gif works as well
Sebastian
Message 15 of 16
VRUSHABH.JOSHI
Resolved thanks
Message 16 of 16
cadffm
FortiGuard is a program on your computer what blocks youtube -links.
Reposting a youtube link will not work on your side.
You solved it by my way: Have fun with fields.
Sebastian
